Help...I forgot to activate flow in DEV before completing update set and moving it to Test
Mike LHCG1
In our  I made some changes to a catalog item DEV environment including updating the flow. However, I forgot to activate the flow before I completed the update set and moved it to test. How can I get the flow to my test environment?
Can I create another update set, activate the flow and then complete and move the update set to test?
Pending an answer, I have not yet activated the flow in Dev.
Thank you.
Dr Atul - LNG
Hi @Mike LHCG1
Yes,  create another update set, activate the flow and then complete and move the update set to test and deploy it after the previous update set.
Dr Atul - LNG
Hi @Mike LHCG1
