Help in Phone Number formatting in variable
Ljone
Giga Contributor
HI Experts,
Kindly help me, I have a mobile number variable in Single line type.
If entered as 0420111111, it should format as +61 420 111 111 and should happen onChange action.
i tried creating an Onchange catalog client script with below code i found but it is only accepting 10 digits and would not display the correct format. ANY HELP WOULD BE APPRECIATED. THANK YOU!
  var pattern = /^\(\d{3}\)\s\d{3}-\d{4}$/; //(xxx) xxx-xxxx
    var phone = g_form.getValue('u_mobile_phone');
    if (!pattern.test(phone)) {
        phone = phone.replace(/\D/g, '');
        var regex = /^\d{10}$/;
        var is_valid = regex.test(phone);
        if (!is_valid) {
            g_form.clearValue('u_mobile_phone');
            alert('Invalid phone number. Please enter 10 digits');
            phone = '(' + phone.slice(0, 3) + ') ' + phone.slice(3, 6) + '-' + phone.slice(6, 10);
            g_form.setValue('u_mobile_phone', phone);
SumanthDosapati
Hi, Try this
	var pattern = /^\+\d{2}(?:\s\d{3}){3}$/;
    if(!pattern.test(newValue))
			var length = g_form.getValue('u_mobile_phone').length;
			if(length != 10)
					g_form.showErrorBox('u_mobile_phone', 'enter 10 digits only');
			else
					g_form.setValue('u_mobile_phone', '+61 ' + newValue.slice(1,4) + ' ' + newValue.slice(4,7) + ' ' + newValue.slice(7));
Example input : 0420111111
Example Output : +61 420 111 111
Example Output : Enter 10 digits error
Mark as correct and helpful if it solved your query.
Sumanth
Sumanth
Aman Kumar S
Hey,
Please try below script:
var phone= g_form.getValue('u_mobile_phone');
var check = /^[0-9]{10}/;
var verify = phone.match(check);
if(verify == "true"){
         var res = phone.slice(1);
         g_form.setValue('u_mobile_phone', '+61 ' + res.slice(0,3) + ' ' + res.slice(3,6) + ' ' + res.slice(6) );
else{
Hi Aman,
I tried this code but it is giving me the alert "Invalid phone number. Please enter 10 digits". Although i have tried several times inputting 10 digits. 😞
SumanthDosapati
Hi, Try this
			if(length != 10)
			else
Sumanth
Sumanth
Thank you, Sumanth! this is working for me! 🙂
@Ljone  Looks like you marked your own answer as correct instead of mine 🙂
