Help with Flow Designer: Automating Microsoft Entra ID (Azure) MFA Reset via Graph API
05-18-2026 03:47 AM
- Custom Action: Uses a REST step to GET v1.0/users/{userEmail}/authentication/methods.
- Script Step: Parses the JSON response into an Array.String of IDs.
- Flow Logic: Uses a For Each loop to iterate through the IDs.
- Delete Step: A second REST call to DELETE v1.0/users/{userEmail}/authentication/methods/{methodId}.
The Issue:
I am consistently receiving a 403 Forbidden (accessDenied) error during the test run, even after refreshing the OAuth token.
Is there anyone who has work on the same requirement , Any advice on the flow logic or the Azure permission side would be greatly appreciated!
05-18-2026 04:26 AM
Hi @SS1510
A 403 Forbidden (accessDenied) error encountered while deleting Entra ID MFA methods is usually caused by insufficient Microsoft Graph API permissions .
Check with Azure team for the required permission. I do not think Azure team will allow to delete the method from their end as it is kind of highest privilege. Still please check with them.
