Help with Json formatting
thirumala2
HI All .,
I am stuck with some issue with Json formatting in the script .Kindly help me and let me know where am I doing mistake:
 // Add your code here
 var pool_members_curr = {};
 var pool_members_ui = {};
 var device = '10.33.120.205';
 var pool_name = 'pool-tcp-443-ey-test-20.20.20.52';
 var request = {};
 var midserver = GlideProperties.get('mid.server.rba_default');
 var gr = new GlideRecord('ecc_agent');
 gr.addQuery('name', midserver);
 gr.next();
 if (gr.status == 'Up') {
     var username = '';
     var password = '';
     var grCreds = new GlideRecord('sys_auth_profile_basic');
     grCreds.addQuery('name', 'F5 Lab');
     grCreds.query();
     var encr = new GlideEncrypter();
     if (grCreds.next()) {
         username_lab = grCreds.username.toString();
         password_lab = encr.decrypt(grCreds.password.toString());
         gs.print('Failed to get credentials for "F5 Lab" auth profile.');
         username = username_lab;
         password = password_lab;
     var r1 = new sn_ws.RESTMessageV2();
     r1.setHttpMethod('post');
     r1.setEndpoint('https://' + device + '/mgmt/shared/authn/login');
     r1.setRequestHeader('Content-Type', 'application/json');
     r1.setRequestBody('{"username":"' + username + '","password":"' + password + '","loginProviderName":"tmos"}');
     r1.setMIDServer(midserver);
     var response1 = r1.execute();
     var responseBody1 = response1.getBody();
     var httpStatus1 = response1.getStatusCode();
     if (httpStatus1 != 200) {
         throw new Error('Getting authentication token from ' + device + ' failed with HTTP Response status: ' + httpStatus1 + ' Response body:' + responseBody1);
         var res_body_json1 = JSON.parse(responseBody1);
         var auth_token = res_body_json1['token']['token'];
     var ritm = new GlideRecord('sc_req_item');
     ritm.addQuery('sys_id', '3f3d1c181ba9c294ae8c43f7cc4bcb5e');
     ritm.query();
     if (ritm.next()) {
         var mem_add_2 = [];
         var member_address = [];
         var mem_add_table = [];
         var add = ritm.variables.f5_active_device;
         var p_name = ritm.variables.pool_name;
         var mrvs_address = JSON.parse(ritm.variables.mvrs_f5_pmm);
         for (var i = 0; i < mrvs_address.length; i++) {
             var member = mrvs_address[i];
             var add_0 = member['name'];
             var member_add = member['address'];
             var add_2 = member_add + ':' + member['port'];
             pool_members_ui = {
                 'name': add_2
             member_address.push(pool_members_ui + '');
             mem_add_2.push(member_add + '');
             gs.print('pool_members_ui' + member_address);
             gs.print('mem_add_2' + mem_add_2);
             var f5_pool_member = new GlideRecord('u_network_f5_pool_members');
             f5_pool_member.addEncodedQuery('u_f5_ipSTARTSWITH' + add);
             f5_pool_member.addQuery('u_pool_name', p_name);
             f5_pool_member.query();
             while (f5_pool_member.next()) {
                 mem_add_table.push(f5_pool_member.u_member_address + '');
             gs.print('mem_add_table ' + mem_add_table);
             var arrayUtil = new ArrayUtil();
             var array3 = arrayUtil.diff(mem_add_table, mem_add_2);
             gs.print('array3 ' + array3);
             gs.print('array3 length ' + array3.length);
             if (array3.length == 0) {
                 gs.print('test');
                 request = {
                     'partition': 'Common',
                     'members': member_address
     gs.print('StrINGIFY ' + JSON.stringify(request) );
End result is something like this :
After members there should be name : value pair  display in place of object object in Stringify .
Deepak Shaerma
Hi @thirumala2
When you see "members": ["[object Object]", "[object Object]", ...] in your JSON.stringify(request) output, it means that the objects weren’t stringified correctly before being added to request.members.
To ensure that request.members contains the proper string representations of your objects (so when you JSON.stringify(request), you get the expected structure),
You want to ensure that each pool_members_ui object is added to the members array as an object rather than a string. Instead of attempting any concatenation or conversion when pushing into member_address, push the object directly:
member_address.push(pool_members_ui);
Assuming your REST API expects request.members to be an array of objects with specific properties, make sure you construct your objects correctly based on the API’s expected schema. For example:
request = {
partition: "Common",
members: member_address // Ensure this is an array of objects
Script:
var username_lab = '';
var password_lab = '';
var request = {};
if (gr.next() && gr.status == 'Up') {
    grCreds.query();
        password_lab = GlideEncrypter().decrypt(grCreds.password.toString());
    r1.setRequestBody(JSON.stringify({
        "username": username_lab,
        "password": password_lab,
        "loginProviderName": "tmos"
    var auth_token = JSON.parse(responseBody1).token.token;
    var mem_add_2 = [];
    ritm.query();
    if (ritm.next()) {
            var member_add = member.address + ':' + member.port;
            pool_members_ui = { name: member_add };
            mem_add_2.push(member.address);
        // Assuming further operations with member_address as needed…
        // Preparing the request options correctly
        request = {
            "partition": "Common",
            "members": member_address
        gs.print('StrINGIFY ' + JSON.stringify(request));
    gs.print('Mid server ' + midserver + ' is down.');
Please Mark this Helpful and Accepted Solution. If this Helps you to understand. This will help both the community and me..
- Keep Learning ‌‌
Thanks & Regards
Deepak Sharma
Hi @thirumala2
It seems there is an issue with the logic of how you're constructing and populating the member_address array within the loop. Please try this-
var request = {};
gr.next();
    var username = '';
    var password = '';
    grCreds.query();
    ritm.query();
    if (ritm.next()) {
        var mem_add_2 = [];
            pool_members_ui = {
                'name': add_2
            member_address.push(pool_members_ui.name);
            mem_add_2.push(member_add);
                mem_add_table.push(f5_pool_member.u_member_address);
                request = {
Hi Amit ,
Thanks for the response .In stringify its blank .
