Help with UI Policy and variables visibility. Variable not visible as expected/UI policies written.
Vaishnavi35
I have built a catalog item,
It should appear this way when certain choices are selected,
But, Vendor/Client checkbox appears on the form without "Visa" checkbox being selected.
Please help?
UI Policies written,
1.
2.
Am i missing something here? Please help?
Vaishnavi
art_jones
Hi Vaishnavi,
what kind of variable is "Who are the intended recipients?" ?
-Art
It was a checkbox earlier , I have changed it to "Label" now.
Vaishnavi
Hi, I'm thinking your issue has to do with the checkbox/label variables and the mandatory setting.  If you change the variables to not mandatory so you still have the issue?
I removed/unchecked this "Selection Required" and it worked correctly. But the requirement I got is they want it as mandatory. How can I achieve that?
Vaishnavi
