05-12-2021 07:19 AM
Hi team,
Im working on Servinow to jira spoke Integration. When someone update problem record(description,category,company,etc) on Servicenow, same updation should be done on JIRA side as well
I created flow designer for create action (its working fine). I need Flow designer for Update action.
I did same steps as mentioned in https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
Still getting error as following:
Any lead will be appreciated.
06-16-2021 07:58 AM
Hi team,
whoever is facing this issue please note:
there is mistake in KB article https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
type of Input 'Additional Fields' is 'String', but in KB article is its 'Name/Value'.
Shrutika
05-12-2021 08:33 AM
check this video for bi-directional JIRA and ServiceNow Integration
https://www.youtube.com/watch?v=lqnOurQlM_U
05-12-2021 08:57 AM
Hey @Ankur bawiskar,
Thanks for your response. But this vdo is regarding When "action is created".
If you see in video, trigger condition is 'Incident is created'.
I want is, When we update record then same update should apply to JIRA too.
Update ACTION is mention in https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
But still we got error. You can check error SS on question itself.
is there any mistake in https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189 ? Because someone modified it 3 days ago.
Not working in Quebec version
05-12-2021 10:08 PM
yes I could see the KB article is updated 4 days ago.
That might be the reason it is not working.
Was this working fine in earlier version?
The error talks about unexpected token so did you check the JSON is proper which is going out from ServiceNow
05-13-2021 06:39 AM
05-13-2021 06:56 AM
Since I could not install JIRA spoke in my PDI I cannot explore much on that.
