Hi Team, need help in Servicenow - JIRA spoke integration
Shrutika Surwad
Hi team,
Im working on Servinow to jira spoke Integration. When someone update problem record(description,category,company,etc) on Servicenow, same updation should be done on JIRA side as well
I created flow designer for create action (its working fine). I need Flow designer for Update action.
I did same steps as mentioned in https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
 Still getting error as following:
Any lead will be appreciated.
Shrutika Surwad
Hi team,
whoever is facing this issue please note:
there is mistake in KB article https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
type of Input 'Additional Fields' is 'String', but in KB article is its 'Name/Value'.
Shrutika
15 REPLIES 15
Shrutika Surwad
Hi team,
Shrutika
Hi @Shrutika Surwade had you got this working?
we are trying to implement this as suggested in KB but getting this error
Any idea where it is going wrong? we have a valid connection and able to update when providing hardcoded issue id
Error: Unexpected token in object literal,Detail: Unexpected token in object literal
Hey,
Just select input type of additional fields to string.
Please go through my answer again
me2
Giga Contributor
Could you please provide the script used? I changed it to string, and I'm still getting an error message.
Farid Shaikh3
Hi Shrutika,
I would like to see the actual script.
SNOW -  Description field is not updating in JIRA. "Update Issue"
I followed and updated my configuration accordingly but still facing error.
Illegal Character...
Thanks in advance.
Farid
