Hi Team, need help in Servicenow - JIRA spoke integration
Shrutika Surwad
Hi team,
Im working on Servinow to jira spoke Integration. When someone update problem record(description,category,company,etc) on Servicenow, same updation should be done on JIRA side as well
I created flow designer for create action (its working fine). I need Flow designer for Update action.
I did same steps as mentioned in https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
 Still getting error as following:
Any lead will be appreciated.
Shrutika Surwad
Hi team,
whoever is facing this issue please note:
there is mistake in KB article https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
type of Input 'Additional Fields' is 'String', but in KB article is its 'Name/Value'.
Shrutika
15 REPLIES 15
Eric Smith
Hey, have you thought about using a 3dr party too for this job, instead of Jira Spoke? Thre are plenty of tools available, which I think would have made the integration easier. We currently use one - zigiops. It works bi-directionally and can be customized to fit our use cases.
