09-12-2025 03:19 AM
Good day!
I created a catalog client script that hide fields if the requested for is member of a group and selected specific request type. It works on the portal, but an issue encountered while changing the requested for field. Can someone know how to configure or fix the script for this? Thanks!
09-12-2025 03:44 AM
You’re using an onChange client script on the request_type variable.
function onChange() { var deptId = g_form.getValue('requested_for_entity'); var requestType = g_form.getDisplayValue('request_type'); ... }This script only runs when request_type changes.
But when you change Requested for, the script doesn’t automatically re-run, so the visibility rules for your fields don’t update.
Fix :Create another onChange Client Script for the variable requested for.
Inside that script, call the same logic you already have (e.g., put your hide/show logic into a reusable
09-12-2025 03:29 AM
it's onLoad or onChange script.
Please share some screenshots and the actual script and config screenshots of that client script
09-12-2025 03:32 AM
Hi, this is the screenshot of the client script. It is an onChange script.
09-12-2025 03:35 AM
your onChange syntax needs to be updated.
if you are changing requested for variable and want same behavior then you should write 1 more onChange catalog client script and it will be for requested_for_entity variable and exact same code.
09-12-2025 03:38 AM
Okay, I will try it. Thank you!
09-12-2025 03:47 AM
Hello, I have tried your proposed solution, but it still does not take effect.
Here is the result:
