how auto populate assignment group on change task as same as change request ??
Siddhesh Gawade
I have requirment  to  auto populate assignment group on change task as same as change request.
var changetask = new GlideRecord('change_task');
changetask.assignment_group = current.assignment_group;
})(current, previous);
but this is not workling please help.
regards,
Siddhesh.
Vaishnavi Lathk
Hello Siddhesh,
Solutions :-->
1) Create a dictionary override for the assignment group field on change task table and use the following script in the default value column
javascript:parent.assignment_group;
2)Code Snippet
Vaishnavi
ishwar09
Hi Siddhesh,
Go to workflow 'Change Request - Normal change tasks' (checkout) > Create Task node > Add this code under Advanced Script section 'task.assignment_group = current.assignment_group;'
It worked for me.
Please mark this if helpful.
