08-22-2018 06:25 AM
How can I autoclose problem after 5 days of resolution
Problem Management
08-22-2018 06:31 AM
I recommend setting a system property (my.problem.resolution.days) and using a scheduled job against it to query for active records that are resolved 5 or more days ago. If you want make this easier... Consider doing this without any script with a simple update set add-on that I made specifically for situations like this.
06-23-2023 12:08 PM
Please fix this link
03-14-2024 06:44 AM
Hello Chuck
Could you please me to get the script needs to be written in scheduled job ?
Thanks in advance
Nagurbee
03-14-2024 06:47 AM
You can use flow designer for this, which will be easy and low code.
03-14-2024 07:51 AM
Do we need to write any script in flow designer ?
Thanks in advance
Nagurbee
03-14-2024 07:53 AM
No mate.
