How can I change colors on the Process Flow Formatter based on the different values?
marcelorsc
Kilo Expert
I would like to change the green color on the process flow formatter to red for an specific value. Has anyone come across this yet?
Marcelo R. S. Correia
Principal Business Consultant
EMC Corporation
13 REPLIES 13
I'm not sure how thrilled I am with this solution, but I've figured out how to do this. The first thing you'll need to do is make a copy of that arrow-point image colored the way you want. Then you can upload the new image via the 'System UI - Images' module. The out-of-box image can be found here...
https://demo.service-now.com/images/chevron_current_.pngx
Once you've done that, then you can set up a client script to modify the arrow color and arrow head image for the currently-selected items in the process flow formatter. Here are the script lines that should work. The script points to 'chevron_current_red.pngx' as the arrow head image. You should change this to be the path to your uploaded image. The second line changes the bar color.
$$('img[src*="chevron_current"]')[0].src='chevron_current_red.pngx';
$$('.process_flow.current')[0].style.backgroundColor='#920000';
Radhika Aluru1
Mega Contributor
Hi Marcelo,
I tried to implement this in my environment. After adding the image and client script, I am getting the attached image. It has three images and all three are in different color.
can you please advise if there is any way to acheive single colour?
Radhika
Hey ,
How did you get it?
Could you please help on this one,...
How to add colors can you please your explanation with screen shots/ script
where i have to write script and what i have to do....
CapaJ
Problem is, there are what looks like eight different chevron images that get used for the state separators in that thing. The boundary between two states is colored on either side based on the color of both the previous and next blocks.
Any attempt to change this would probably need to change all eight of those images.
Manjul Katare
Here is the fix if you are on Dublin/Eureka or any prior releases. But if you are in Fuji OR planning to upgrade to Fuji then I would advice NOT to use this fix as UI design in Fuji is really good.....Trust me you don't wanna customize it !
Here is the fix for Eureka or any other older releases, Please follow the steps below:
#1. Update the UI Macro name "process_flow".
URL : https://<instance-name>.service-now.com/nav_to.do?uri=sys_ui_macro.do?sys_id=4bcb4b840a0a0b9f00ae822ff0cef724
#2. Take the below code — We are adding some styles and changing the source for images being used.
<style>
table.process_flow_formatter {
  margin-left: -9px;
table.process_flow_formatter tr td,
table.process_flow_formatter tr td.process_flow.future,
table.process_flow_formatter tr td.process_flow.current,
table.process_flow_formatter tr td.process_flow.past {
  color: #ffffff;
  height: 24px;
  font-size: 15px;
table.process_flow_formatter tr td.process_flow.current {
  background-color: #d1232b;
  background-color: #847c7c;
</style>
  <link rel="stylesheet" type="text/css" href="styles/process_flow_formatter.cssx"></link>
  <tr>
      <td colspan="2" width="100%" nowrap="true">
          <div>
  <table class="process_flow_formatter" width="100%" cellpadding="0" cellspacing="0">
    <tr>
        <g2:flow_formatter var="jvar_flows" table="$[${ref_parent}.getRecordClassName()]" current="$[${ref_parent}]" />
        <j2:forEach items="$[jvar_flows]" var="jvar_flow">
            <td class="process_flow $[jvar_flow.getParameter('state')]" title="$[jvar_flow.getLabel()]">
            </td>
            <td width="16" height="100%">
  <img style="height:24px; width:21px; margin:0px; padding:0px;"
          src="chevron_$[jvar_flow.getParameter('state')]_$[jvar_flow.getParameter('next_state')].pngx" />
            </td>
        </j2:forEach>
    </tr>
  </table>
          </div>
      </td>
  </tr>
</j:jelly>
#3.   Upload the images and make sure your images   are named like these:
#4. You should get the end result as show below:
Before:
After:
Why you should not be change the process formatter if you are in Fuji or newer release?
As you can see there is no image being used, its more modern and blends well with forms. it really feels like iOS design
Hope this helps!
-Manjul
