How can I Print Bar code Labels
Mark Lanning
Looking for a How to:
Issue: We need to be able to print a Bar Code Label from ServiceNow!
Fields used for Information: Number / Asset Tag / PO / Serial Number
Have been told we will need the following:
1. Able to put in dimensions of label
2. Sequence Numbering for Equipment Tag ( Needs to be 8 digits )
3. Along with Bar Code want Asset Tag and Serial Number to also print on Label
4. Printer Type ( Zebra , Intermec ,Xerox, etc )
Can anyone point me in the right direction!
Mark
Jace Benson
Looking at some things online, looks like this has been solved already.
See: https://github.com/lindell/JsBarcode/
So I thought I'd give it a try.
I'm not sure how you'll solve the dimension issue but with this library it's not that bad.
Steps to recreate;
1.  Create UI Script and copy/paste the library code from: https://cdn.jsdelivr.net/jsbarcode/3.3.20/JsBarcode.all.min.js
2.  Create UI Macro with svg with id you will call later.
3.  Create UI Formatter calling UI Macro name plus .xml
4.  Add UI Formatter to form.
5.  Add onChange script like so to form;
   * Run on load and on change.
	ScriptLoader.getScripts('jsbarcode.jsdbx', function() {
		console.log('onchange');
		JsBarcode("#code128", newValue);
/*		JsBarcode("#ean-13", "1234567890128", {format: "ean13"});
		JsBarcode("#ean-8", "12345670", {format: "ean8"});
		JsBarcode("#ean-5", "12345", {format: "ean5"});
		JsBarcode("#ean-2", "12", {format: "ean2"});
		JsBarcode("#upc-a", "123456789012", {format: "upc"});
		JsBarcode("#code39", "Hello", {format: "code39"});
		JsBarcode("#itf-14", "1234567890123", {format: "itf14"});
		JsBarcode("#msi", "123456", {format: "msi"});
		JsBarcode("#pharmacode", "12345", {format: "pharmacode"});
Then it works onload and onchange.
16 REPLIES 16
it's not working for me either.
me too
Can you share how it's not working or where it fails?
Are you getting any errors?
Do you have this in a update set or scoped application on git I can checkout?
Jan Brani_
Working for me, thank you very much!
some of the steps could be explained in more detail, but with some ingenuity, it is not a problem.
You are a man! 🙂
I'm so glad it helped!  Feel free to rewrite it in your own words.
