How can w use wait for condition in flow designer for variable?
08-04-2023 12:53 AM
I have one variable return date on catalog item and I am using flow designer for my catalog item,
After closing one task I am putting RITM into pending requester and that time one variable will visible for user " return date" and when he will submit value in that variable then I have to set RITM as work in progress and I have to create new task.
Above requirement I am trying to achieve wait for condition but there I am not getting variable value
I want to check if return date is not empty then I can move forward my flow.
Can someone help me please??
08-04-2023 07:51 AM
Thanks for sharing solution, lesson learned 😁
03-13-2024 02:01 AM
This is a nice trick. Thanks a lot
11-28-2024 02:13 AM
I have a similar requirement. in sctask we have a variable "need attention" with values yes/no. So if we select yes then it should create new task or it should not. so i am using wait for condition with sc task record but i am not getting variables from sctask.
Any help on this please?
08-04-2023 02:47 AM
check steps shared by Anil. those should help you
