How Display Approvers in Flow designer Stages
Guilherme Popo2
I have this requirement to display approvers in the Service Portal using Flow Designer (example in the image below), but I can't find anything about it, just using Workflow.
Is it possible to do this using Flow?
Hi @Guilherme Popo2
for Flow Designer, this is not possible. You may need to use Workflow to achieve.
Thanks and Regards
Sai Venkatesh
SAI VENKATESH
Hi @Guilherme Popo2
It is possible using flow deisgner. You can add stages .attached is the image. You can create the stages names as per your need
Thanks and Regards
Sai Venkatesh
Hi @SAI VENKATESH,
Thanks for replying, but it's possible display the approvers names in the stages using Flow designer?
Hi @Guilherme Popo2
Thanks and Regards
Sai Venkatesh
