How do I stop a background script from running
Priyanka Mathur
Hi Experts,
How can I stop a background script from running.
Priyanka
23 REPLIES 23
Ankur Bawiskar
As mentioned by members find the transaction and kill it.
refer below additional link
https://www.servicenowelite.com/blog/2016/11/4/viewing-and-killing-transactions
@Priyanka Mathur
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
@Priyanka Mathur
If my response helped you please mark response as correct and close the thread so that it benefits future readers as well.
AkshayBhask
Hi Priyanka,
1st Method :
As Hemant & Suseela suggested - you can go to -
1. ServiceNow Filter Navigator > System Diagnostics > All Active Transactions (Nodes)
2. Find the latest record which is being created by you or updated by you
3. Select that record and click on the selection - Kill in the dropdown
2nd Method :
Allow the background script to run till its completed and rollback the action that you executed. It will ensure that all modifications are reverted.
Hi Akshay,
Can you please tell me how much time, does it take for the background script to be complete?
Priyanka
