How set a default value using dictionary entry
06-22-2020 05:37 AM
06-22-2020 06:43 AM
That is expected as per your client script it will set the Value to 'No' even after you save the form & load if the Group is the sys_id you using for comparing.
If you are using the dictionary default value no need of Client script as above. You can mark it false.
06-22-2020 06:51 AM
Yes, it is inactive.
06-22-2020 06:56 AM
Since, you confirm there is no client script additionally. Can you try one by Making the Label & Value to be same.
Label- No Value -No
Label-Yes Value-Yes
& then update the Default Value: No accordingly.
06-22-2020 05:58 AM
Yes this is correct.
Good you are following this approach.
Ashutosh
06-22-2020 06:13 AM
But it's showing "Yes" by default. Please help.
