How to add 10 days to current date using client scripts
anur
I have a field "RequestedDate" in a service catalog form. Need to populate it with value equal to current date plus 10 days.
Please suggest implementing this with a client script.
You can do it by setting the default value of the variable. You can check the below blog
Auto-populating and validating date fields
Sriramachandra
// Get start date from field
var startDateStr = g_form.getValue('u_start_date');
var startDate = new Date(startDateStr);
// Add 5 days
startDate.setDate(startDate.getDate() + 5);
// Format to user's date format or standard YYYY-MM-DD
var yyyy = startDate.getFullYear();
var mm = String(startDate.getMonth() + 1).padStart(2, '0');
var dd = String(startDate.getDate()).padStart(2, '0');
var formattedEndDate = yyyy + '-' + mm + '-' + dd;
// Set the value in 'u_end_date' field
g_form.setValue('u_end_date', formattedEndDate);
Sriramachandra
if (isLoading || newValue === '') return;
var endDateStr = g_form.getValue('u_end_date');
if (!startDateStr || !endDateStr) return;
var endDate = new Date(endDateStr);
var diffTime = endDate - startDate;
var diffDays = diffTime / (1000 * 60 * 60 * 24);
if (diffDays < 0) {
g_form.showFieldMsg('u_end_date', 'End date cannot be before start date.', 'error');
g_form.setValue('u_end_date', '');
} else if (diffDays > 365) {
g_form.showFieldMsg('u_end_date', 'End date cannot be more than 365 days from start date.', 'error');
