How to add a link(url) by using g_form.showFieldMessage()?
Bharath kumar6
I need a link to be displayed if a user select "No" from Yes/No field.
How do I achieve this?
Ankur Bawiskar
g_form.showFieldMessage() -> doesn't support showing links
you can use info message to show the link
9 REPLIES 9
No bud, lots of discussions have happened on this but no good solution ever came out.
You can add a link to the label of the field but that will always be present regardless of the value selected.
Alert also wont support hyperlink.
You can try creating a ui page and trigger that on change and add link on the ui page. That is the closest you can get to this requirement.
okay.
can you please explain a bit on this - "You can try creating a ui page and trigger that on change and add link on the ui page. That is the closest you can get to this requirement."
Here it is,
Create a UI page like below
<a href="https://www.google.com" target="_blank">Link</a>
</j:jelly>
On Change Client Script to run this when the value selected is NO
var gm = new GlideModal("Test Page For Comm");
gm.setTitle('Show title'); // Add meaningful title
gm.setWidth(550); //Adjust accordingly
//Opens the dialog
gm.render();
Result:
-Anurag
this does not work on service portal
This is a very useful trick to know.  Thanks!
