How to add double quotes to array values
Shalani Rajendr
I need to add double quotes to values in an array please help me on how to do that.
Example: var arr=["servicenow,community"];
I have an array like this but i need the array as var arr=["servicenow","community"]; via server script
Please tell me on how to solve this
Vitali1
It looks like you have a value as a string but need to have multiple values instead.
You could try to split this string into multiple values before putting it in the array.
try this one
var someValue = "servicenow,community";
arr = someValue.split(',');
gs.print(arr);
14 REPLIES 14
Hi Upender ,
I need to convert my script as
""+table+"'",""+query+""
Is it possible?
If not , is their any way to achieve it?
Hi Shalani,
If array is like that arr=["servicenow,community"], means it is having only one element.
Then you can try as below
gs.print(arr)
var arr1=arr[0].split(",");
gs.print(arr1)
Now arr1 become the array of two elements.
If my answer replied your question please mark appropriate response as correct so that the question will appear as resolved for other users who may have a similar question in the future.
Saurabh
No it dint work sorry!
It is working if you are getting an array with single element. You want to seperate it, below code is working.
If you are expecting something else then please elaborate more.
Run the below code in background script
gs.print(arr+": "+arr.length)
gs.print(arr1+": "+arr1.length)
Output:
Saurabh
Output:
Saurabh
