How to add hyperlink in catalog (checkbox field in catalog item) item
chandan31
How to add hyperlink in catalog (checkbox field in catalog item) item.
Thanks and Regards,
Chandan Patra
2 ACCEPTED SOLUTIONS
Hello @chandan31
have you referred second thread. the requirement is quite similar.
if your requirement is to show hyper link when checkbox clicked, you can do it via on change client script.
refer: Solved: hyperlink in on-change client script - ServiceNow Community
Please hit the thumb and Mark as correct based on Impact!!
Kind Regards,
Ravi Chandra.
Ankur Bawiskar
@chandan31
did you try to create checkbox variable and show some field message on form load?
11 REPLIES 11
@chandan31
it doesn't support html tags.
I informed to use field message via script when form loads
can you give me the thread
