How to add My Groups Work and edited gauges to ITIL homepage?
Megan C
Kilo Expert
This is a 2 part question that I'm hoping has the same answer.
1) If a user removes My Groups Work from the ITIL homepage, where do you find it to add it back?  I can't find it in the Add Content frame.
2) I created a 2nd gauge similar to My Groups Work with an additional filter.  But again, I can't find it to add to the ITIL homepage.
Anirban Roy
Mega Guru
My Groups work is a gauge whose type is 'list' by default. (the type 'list' option is now deprecated.)
I just changed the type to an option - 'count' and the gauge is now selectable
Anirban
11 REPLIES 11
Thank you for this I did not know about the type 'list' option is now deprecated.
Anirban Roy
Mega Guru
Hi Megan,
As we discussed, widgets need to be created for way forward.
In case, you are trying to rollback to the old situation, I am attaching you the xmls, you can import in your instance. (first test in personal instance)
Steps to rollback:
1. Delete all the existing dropzones and related portal preferences for the 'ITIL Homepage' page
2. Impor the xmls I have attached here (first import the xml which contains pages, then import the xml which contains portal preferences)
A screenshot for reference(I was able to revert back the 'My groups work' gauge in the 'ITIL Homepage'):
Hope it helps.
Please mark the response correct and helpful, if it helps.
Anirban
