How to Add or Remove Users in Group.(Using Workflow).
Para5
1. I have created one catalog item "Add Remove client portal Admnistrators".
2.On this catalog item added two variables:
    1.Contact to Add - When the User move in Selected, Automatically add to the 'Client portal group'
    2.Contact to Remove - When User move in Available,Automatically remove from the 'Client portal group'.
3.My requirement is adding or removing users from the 'Client portal group'. I want to implement this using workflow.
   Thank You.
try this
var usersToAdd = current.variables.contact_to_add.toString().split(','); // give correct variable name here
var usersToRemove = current.variables.contact_to_remove.toString(); // give correct variable name here
var rec = new GlideRecord('sys_user_grmember');
rec.addQuery("group.name", "Client portal group");
rec.addQuery("user", 'IN', usersToRemove);
rec.query();
while(rec.next())
    rec.deleteRecord();
for(var i in usersToAdd){
    var rec1 = new GlideRecord('sys_user_grmember');
    rec1.addQuery("user", usersToAdd[i]);
    rec1.addQuery("group.name", "Client portal group");
    rec1.query();
    if(!rec1.hasNext()){
        rec1.initialize();
        rec1.user = usersToAdd[i];
        rec1.setDisplayValue('group', "Client portal group");
        rec1.insert();
regards
14 REPLIES 14
@Ankur Bawiskar, Below is the script
var usersToRemove = current.variables.contact_to_remove; // give correct variable name here
rec.query();
while(rec.next())
    rec.deleteRecord();
    rec1.query();
        rec1.initialize();
        rec1.insert();
I have added Abel Tuter and Removed same .
try this
rec.query();
while(rec.next())
    rec.deleteRecord();
    rec1.query();
        rec1.initialize();
        rec1.insert();
regards
Thanks @Ankur Bawiskar for your reply......
I have added if condition in workflow.(current.variables.contact_to_add !=' ') i.e Variable A. And split the above scripts into two parts.This is works for me.
@Sonu Parab
I could see you marked my response as correct earlier and now it is not.
You already told my script was working fine. You just had to enhance the logic with your development skills.
Would you mind marking my response as correct?
Yes @Ankur Bawiskar
