how to add timezone in standard way
i have added some timezones to SYS_USER table but they are not working properly
by default system has some timezones and UTC-5 US/Eastern Time is one of them this is working fine but i added UTC+530 India Time, and that is not working . can you plz let me know what is standard way to write timezones or any standard way to do this.
If you want to add it to the choice list, you can. Instead of Configure Choices, use Show Choices.
Add the entry like this:
thanks , but one things how WRITING IST will automatically calculate this , is there some back coding from where it will match its value to utc+5:30 ?
My understanding is that it gets it from the OS (or some shared library at the filesystem/OS level.)
