How to auto populate Assignment Group based on Category and SubCategory
Renata9
Is there a way to auto-populate the assignment group based on the criteria of the category and sub-category? For example, if the category is bi team and the subgroup is Cyberquery the assignment group will automatically populate to the BI Team.
Saurav11
Hello
There are quite a few ways to do it
Onchange client script
Business rule
Assignment rule
It's upto you how you want to do it based on your instance setup
Please mark answer correct/helpful based on impact
17 REPLIES 17
Renata9
I tried to do the Assignment Rule and made the changes. When I go to the incident form and select BI Team the assignment group does not change.
Hi Renata,
In the "Applies To" add additional  ADD condition "sub-category is Cyberquery".
Hope it helps.
Raj
Renata9
I tried to add the filter conditions and I still do not see a change when the category and/or subcategory are selected.
Hi Renata,
 Try as follows:
Raj
Renata9
I have tried with one category and could not get it to work. I also tried by just using the category only as well.
