How to auto populate Assignment Group based on Category and SubCategory
Renata9
Is there a way to auto-populate the assignment group based on the criteria of the category and sub-category? For example, if the category is bi team and the subgroup is Cyberquery the assignment group will automatically populate to the BI Team.
Saurav11
Hello
There are quite a few ways to do it
Onchange client script
Business rule
Assignment rule
It's upto you how you want to do it based on your instance setup
Please mark answer correct/helpful based on impact
17 REPLIES 17
That's strange, can you paste the full screenshot.
Have you tried to like the above screenshot which I sent?
--Raj | ServiceNow Certified Technical Architect
Renata9
I attached the screenshot. The default assignment group still will not change when the category is selected.
Renata9
Use Assignment Data Lookup
Hope it helps.
Raj
Renata9
Thanks for the response, but it does not change when the Assignment group does not change from the default when the Category is selected.
