How to auto populate Assignment Group based on Category and SubCategory
Renata9
Is there a way to auto-populate the assignment group based on the criteria of the category and sub-category? For example, if the category is bi team and the subgroup is Cyberquery the assignment group will automatically populate to the BI Team.
Saurav11
Hello
There are quite a few ways to do it
Onchange client script
Business rule
Assignment rule
It's upto you how you want to do it based on your instance setup
Please mark answer correct/helpful based on impact
17 REPLIES 17
Terry23
I faced same issue and discovered that since I already had a default Assignment Group, the Assignment Rule will not work.  Please refer to attached.
Can you please share the onChange script? I am attempting to do the same where the assignment group will populate based of category and subcategory, but it does not take the script it leaves the assignment group no matter what catg. or subcateg. was selected. Thank you!
manikanta ravel
Actual Task: In incident form , based on category assignment group needs to be auto populated.
I wrote a Business Rule to auto populate assignment group based on category.
when to run: before
checked: insert and update
(function executeRule(current, previous /*null when async*/ ) {
    if (current.category.changes()) {
        var assignmentGroup = new GlideRecord('sys_user_group');
        assignmentGroup.addQuery('category', current.category);
        assignmentGroup.query();
        if (assignmentGroup.next()) {
            current.assignment_group = assignmentGroup.sys_id;
     } // Add your code here
})(current, previous);
when my businessrule  is not working properly.
