How to Auto populate the task_incident values from parent incident (Only when i click on new button in task incident then populate parent incident details).
Sidhu9
Srinu
approach using display BR + onLoad client script on incident_task
1) Create a Display Business Rule on your Incident Task Table and use the script mentioned below:
	// Add your code here
	g_scratchpad.shortDescription = current.parent.short_description;
	g_scratchpad.description = current.parent.description;
})(current, previous);
 2) Write an On Load Client Script on Incident Task Table with below Code:
function onLoad() {
   g_form.setValue('short_description', g_scratchpad.shortDescription);
   g_form.setValue('description', g_scratchpad.description);
what is not working?
what scripts have you written?
what debugging have you performed?
Did you enhance the script as per your requirement?
Vaishnavi Lathk
Hey  srinu
You can use before insert as following code:-
Apply on Incident table
var gr=new GlideRecord('u_incident_task');
gr.initialize();
gr.short_description=current.short_description;
gr.description=current.description;
gr.parent=current.sys_id;
gr.insert();
