How to automatically add new users to a group when they are added to users
Gemma4
Hi everyone!
I would like to ask your assistance, I have this requirement when a new user is added to the sys_users table I need them automatically added to the PM submitter group. I created a business rule but it is not automatically adding new users. Any suggestions on what the best practice to achieve this would be.
thanks
Hello @Gemma4 ,
What I observed in the First screenshot, You added Group as PM Submitter, but you forgot to add the User field with the value from Trigger->User Record
Please check the Second Screenshot from my Answer
I hope this clears your question
Please mark my answer helpful and correct, If it helps you
Thank you
Please mark my answer helpful & correct if it helps you
Thank you
G Ramana Murthy
ServiceNow Developer
11 REPLIES 11
Thanks so much @RAMANA MURTHY G That worked perfectly!
Hello @Gemma4 ,
Try this flow designer method, it works accurately, I checked in PDI for many times it executes as expected.
Thank you
Thank you
G Ramana Murthy
