How to call a property in flow designer
Krishna Chaitan
HI,
I have a requirement to call a property in flow designer to assign ticket to one group. Can some one help how to call property in flow designer.
Chander Bhusha1
Hi Krishan,
You can use :
gs.getProperty('property_name') in place of getProperty();
Mark helpful and correct if it helps.
CB
Chander Bhusha1
Hi Krishan,
You can use :
CB
Ankur Bawiskar
Hi Krishna,
it should allow server side scripting
ensure you use valid syntax
return gs.getProperty('glide.midserver_SD');
