How to call flow designer inside flow designer
04-24-2024 11:42 PM - edited 04-24-2024 11:46 PM
I have created multiple RITM through flow designer and want to attach same flow for each RITM.
we have Code snippet option of flow designer ,how to use that to attach same flow for every RITM.
04-24-2024 11:50 PM
Hi there,
Can you share any details of your setup?
Kind regards,
Mark Roethof
10x ServiceNow MVP
04-25-2024 12:01 AM
Hi Mark,
I have created flow designer where i have list collector variable
based on records on list variable created RITMs
and for this each RITM want to attach same flow which will add approval and update RITM each separately.
how to achieve this?
04-25-2024 12:36 AM
Have you also considered using the "Submit Catalog Item Request" Action?
Kind regards,
Mark Roethof
10x ServiceNow MVP
04-25-2024 12:46 AM - edited 04-25-2024 04:14 AM
I am not considering 'Submit Catalog Item Request' if i use this it will create req along with that.
In my requirement i have one REQ and multiple RITM.RITM is only for update respective item.
using this video for reference but here want it for multiple RITM and script should be inside the flow. @Community Alums how to achieve this?
https://www.youtube.com/watch?v=H3WGOq69Oes&list=PLgMvigbxmqHR4YKCcx2Yrqh29i8xogcYz&index=11
