how to Call UI action in client script
Shruthi2
I have to hide a Ui action on the change form on change of the configuration item. How do I refer to the UI action in the on change client script of the configuration item field.Please help me out
Shruthi.
Hi Shruthi,
Did you set this field to false?
Isolate Script -  false
  • This field is not on form but from list you can make it false
  • by default it is true
  • If that is true DOM won't work
17 REPLIES 17
please don't use GlideRecord in client script as it is not best practice
Also avoid DOM as this may lead to issue going in future during upgrade etc
Hi ,
I have done this disable the ui action (form link)
Client Script:
var data = g_form.getValue('cmdb_ci');
var agg = new GlideRecord('cmdb_ci');
agg.addQuery('sys_id', data);
// agg.addAggregate('COUNT', 'sys_class_name');
agg.orderBy('sys_class_name');
agg.query();
while (agg.next()) {
var name = agg.getValue('sys_class_name');
//alert(name);
//alert(data);
document.getElementById('8b6441e5db629410a2c89cd5ca9619b2').disabled = true;
its not working
Suseela Peddise
It is not recommended to hide UI action using client scripts or UI policies.
You can use UI action condition to show or hide button on the form.
If you still require , see the below link
https://community.servicenow.com/community?id=community_blog&sys_id=127d6269dbd0dbc01dcaf3231f961973
Hope this helps!
If I have answered your question, please mark my response as correct and/or helpful.
Suseela P.
Hi ,
I had been thru this post unfortunately I was not able to access the class name or the action name or the id . can you please me
Hi Shruthi,
Have you tried putting any alert message to see the script is running?
Share the script that you were trying.
Suseela P.
