how to Call UI action in client script
Shruthi2
I have to hide a Ui action on the change form on change of the configuration item. How do I refer to the UI action in the on change client script of the configuration item field.Please help me out
Shruthi.
Hi Shruthi,
Did you set this field to false?
Isolate Script -  false
  • This field is not on form but from list you can make it false
  • by default it is true
  • If that is true DOM won't work
17 REPLIES 17
Nitin_NOW
Hello
You don't have to call the UI action into Client Script. This can be done directly from the UI action.
In the Condition field of the button use this - current.<field name>.changes()
Please hit correct if this resolves your issue.
Nitin
Gaurav Shirsat
Hi
Place a function in an onload script (only works in global scope)
  1. Client Script function onLoad() { } // You can call this in UI Actions // Only works in global scope (does not work in scoped apps) // Will only work for UI Action of the same table function yourFunctionHere() { // Code here }
  2. UI Action yourFunctionHere();
Client Script
function onLoad() {
// Code here
UI Action
yourFunctionHere();
2) Write a UI Script
UI Script yourFunctionHere
// This will be callable from all client scripts form any table
// If global is not ticked, you must use ScriptLoader API
// Code here
UI Action
//If global is not ticked on UI Script
getScripts("yourFunctionHere", runScripts)
function runScripts() {
yourFunctionHere();
//If global is ticked on UI Script
yourFunctionHere();
Please Mark Correct and Helpful
Thanks and Regards
Gaurav Shirsat
Is it possible to make a call from catalog client script [OnSubmit] to Flow designer action ?
