How to call workflow from script include
‎02-15-2022 01:45 AM
I need to call the workflow from client-side code using script include. I have tried with the below code but it did not work.
Can anyone please help me to solve this issue? I am unable to call the workflow through this code.
Clientside code :
function setRedirect() {
current.u_next_state = '4';
var workflow = new GlideAjax("YaraNSSRWorkflowUtil");
workflow.addParam("sysparm_name", "getDesignWorkflow");
workflow.addParam("sysparm_profile", g_form.getUniqueValue());
workflow.getXMLAnswer(function(answer) {
answer;
Script Include Code:
getDesignWorkflow: function() {
var w = new Workflow();
var name = this.getParameter("sysparm_profile");
var wfContext = new GlideRecord('wf_context');
wfContext.addQuery('sys_id', name);
wfContext.addQuery('workflow_version.name', "Yara_NSSR_Before_Design_Approvals");
wfContext.query();
if (!wfContext.next()) {
var wf = new GlideRecord("wf_workflow");
if (wf.get("name", "Yara_NSSR_Before_Design_Approvals"))
return w.startFlow(wf.sys_id, current, current.operation());
‎02-16-2022 12:32 AM
If the requirement is there we can use UI action as Client + Server
Ensure you don't use GlideRecord in client side code of UI action as it is not best practice.
you can use GlideAjax if you wish to perform some validation or check
‎02-16-2022 12:58 AM
Hello Ankur,
Okay thanks, But I am unable to call the workflow in the script include. Can you please help me with that?
‎02-16-2022 01:05 AM
use GlideAjax and send current record sys_id using g_form.getUniqueValue()
and then use this script
wfContext.addQuery('id', this.getParameter('sysparm_sysId'));
wfContext.query();
wf.startFlow(wf1.getWorkflowFromName('Yara_NSSR_Before_Design_Approvals'), current, 'update');
‎02-16-2022 02:54 AM
Hello Ankur,
I have tried with the below code but it's not triggering the workflow. Can you please look into it and advise?
Ui action script:
workflow.addParam("sysparm_sysId", g_form.getUniqueValue());
answer;
current.update();
Script include code:
var ans;
wfContext.query();
ans = wf.startFlow(wf1.getWorkflowFromName('Yara_NSSR_Before_Design_Approvals'), current, 'update');
return ans;
‎02-16-2022 03:25 AM
which approach you want? because your have mixed up Ajax with Server side
only server?
OR
client + server?
