How to call workflow from script include
‎02-15-2022 01:45 AM
I need to call the workflow from client-side code using script include. I have tried with the below code but it did not work.
Can anyone please help me to solve this issue? I am unable to call the workflow through this code.
Clientside code :
function setRedirect() {
current.u_next_state = '4';
var workflow = new GlideAjax("YaraNSSRWorkflowUtil");
workflow.addParam("sysparm_name", "getDesignWorkflow");
workflow.addParam("sysparm_profile", g_form.getUniqueValue());
workflow.getXMLAnswer(function(answer) {
answer;
Script Include Code:
getDesignWorkflow: function() {
var w = new Workflow();
var name = this.getParameter("sysparm_profile");
var wfContext = new GlideRecord('wf_context');
wfContext.addQuery('sys_id', name);
wfContext.addQuery('workflow_version.name', "Yara_NSSR_Before_Design_Approvals");
wfContext.query();
if (!wfContext.next()) {
var wf = new GlideRecord("wf_workflow");
if (wf.get("name", "Yara_NSSR_Before_Design_Approvals"))
return w.startFlow(wf.sys_id, current, current.operation());
‎02-17-2022 12:58 AM
I believe I have provided enough help on your questions.
The script I shared will work fine provided you debug and find the issue such as is script include client callable, any error in script by adding logs etc
‎04-06-2022 02:06 AM
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
‎09-08-2022 05:26 AM
‎02-15-2022 02:01 AM
‎02-15-2022 01:51 AM
One more basic, 'current' object doesn't work in Client script so I presume your client script is not even calling script include.
Thank you
Prasad
Not required query the "wf_context" table?
