How to check attachment before on submit client script in catalog item
dheeru_1994
Hii All
i am writing this script in catalog item to know that item has attachment attached or not  on submit client script but
error getting
below is the code
function onSubmit() {
    // Check if attachments exist
    var attachment = g_form.getAttachmentList();
    if (attachment.length > 0) {
        // If attachments are found, allow submission
        alert('Attachments found.');
        return true;
        // If no attachments found, prevent submission and prompt user
        alert('Please attach a file.');
        return false;
when i order item   error occure  Error MessageonSubmit   script error: TypeError: g_form.hasAttachmentList is not a function:
function () { [native code] }
glide record and script include not to use  is here anyone who can solve the issue now
HI @dheeru_1994 please try to second approach
Script: onSubmit
Note: Ensure Isolate Script field is set to False for this Catalog Client Script to ensure DOM manipulation works
var countRequired = 1;
	if(window == null){
		// portal
		if(this.document.getElementsByClassName('get-attachment').length != countRequired) {
			alert('You must add 1 attachments before submitting this request.');
			return false;
	else{
		// native view
         var length = $j("li.attachment_list_items").find("span").length;
		if(length != countRequired){
			return false;
Please mark reply as Helpful/Correct, if applicable. Thanks!
@dheeru_1994  did you get the solution of this? I also have similar requirement and don't see any option.
AlpUtkuM
You can use out of box "Mandatory Attachment" checkbox under Portal Settings tab of Catalog Items.
You don't need to write code for this.
ChandanKuma
Is there any way of doing it without DOM manipulation and with GlideAjax
