how to check whether record exists in related list using BR
sasi
Hi ,
i want to check whether there is at least one record in related list , if it is there fine. if there is no record show error message that as "please add one record at least"
and these check has to done when it is changing from new to work in progress.
12 REPLIES 12
Hi Sasi,
If my answer is helpful please mark my appropriate answer as correct.
Hi @Balaji
I have the same requirement on change form, incidents pending related list tab should have atleast one entry.
I used the same code on  change table using before business rule (update ) with filter conditions as priority 1 ,breakfix as ABC and classification as DEF
(function executeRule(current, previous /*null when async*/) {
  var inc = new GlideRecord("incident");
  inc.addQuery("parent", current.getUniqueValue()); // set the condition
  inc.query();
  if(!inc.hasnext())
  gs.addErrorMessage(" reject ");
  current.setAbortAction(true);
 })(current, previous);
It is throwing the error message but classification value is changing from DEF to xxx(previous value) after adding incident to the related tab and also showing error message if there is an entry already.
Can you please help in fixing the code
Hi Sasi,
Here is the code:
Onsubmit script
function onSubmit() {
  var istrue = g_form.getValue('u_relate_to_project');
  if(istrue == 'true')
  var curSysid = g_form.getUniqueValue();
  var ga = new GlideAjax('check_projects_exists');
 ga.addParam('sysparm_name','isProjectExist');
  ga.addParam('sysparm_currentsysid', curSysid);
  ga.getXMLWait();
  var answer = ga.getAnswer();
  if(answer == 'Not Exist')
  alert('please add one record at least');
  return false;
__________________________________
scriptInclude
Active : true
Client callable : true
Script:
var check_projects_exists = Class.create();
check_projects_exists.prototype = Object.extendsObject(AbstractAjaxProcessor,
  isProjectExist: function()
  var answer ='';
  var cursysid = this.getParameter('sysparm_currentsysid');
  gs.log('cursysid :'+cursysid);
  var gr = new GlideRecord('task');
  gr.addQuery('parent', cursysid);
  if(!gr.next())
  answer = "Not Exist";
  else
  answer = "Exist";
  return answer;
Please mark my answer as Correct & Helpful, if applicable.
Sandeep
