How to close problem ticket or change request using background script.
01-18-2025 09:20 PM
Hi Team,
How to close change request or problem ticket using background script as it is process flow , before closing do we need to complete steps? please help on these. I know we can cancel it directly , but cant close it.
Incident Management
01-18-2025 11:43 PM
Hi @VyankteshK ,
You can use below code in background script to close the change and problem.
for change
// Get the Change Request record
var changeRequest = new GlideRecord('change_request'); // Table name for Change Request
if (changeRequest.get('<CHANGE_REQUEST_SYS_ID>')) { // Replace with the sys_id of the record
// Ensure all associated tasks are closed
var changeTasks = new GlideRecord('change_task'); // Table name for Change Tasks
changeTasks.addQuery('change_request', changeRequest.sys_id);
changeTasks.query();
while (changeTasks.next()) {
if (changeTasks.state != 3) { // Assuming 3 is 'Closed' state for tasks
changeTasks.state = 3;
changeTasks.update();
// Check if approvals are completed (if applicable)
if (changeRequest.approval == 'approved') { // Assuming 'approved' is the required state
changeRequest.state = 4; // Assuming 4 is 'Closed' state for Change Request
changeRequest.close_code = 'successful'; // Example close code
changeRequest.close_notes = 'Closed via background script';
changeRequest.update();
gs.print('Change Request closed successfully.');
gs.print('Change Request cannot be closed. Approvals are not completed.');
gs.print('Change Request not found.');
for problem.
// Get the Problem record
var problemTicket = new GlideRecord('problem'); // Table name for Problem
if (problemTicket.get('<PROBLEM_TICKET_SYS_ID>')) { // Replace with the sys_id of the record
// Ensure all associated incidents are resolved/closed
var relatedIncidents = new GlideRecord('incident'); // Table name for Incidents
relatedIncidents.addQuery('problem_id', problemTicket.sys_id);
relatedIncidents.query();
while (relatedIncidents.next()) {
if (relatedIncidents.state != 7) { // Assuming 7 is 'Closed' state for incidents
relatedIncidents.state = 7;
relatedIncidents.close_code = 'Resolved';
relatedIncidents.close_notes = 'Closed as part of Problem resolution';
relatedIncidents.update();
// Set Problem state to Closed
if (problemTicket.state == 4) { // Assuming 4 is 'Resolved' state for Problem
problemTicket.state = 6; // Assuming 6 is 'Closed' state for Problem
problemTicket.close_notes = 'Problem closed via background script';
problemTicket.update();
gs.print('Problem ticket closed successfully.');
gs.print('Problem ticket cannot be closed. It must be in Resolved state first.');
gs.print('Problem ticket not found.');
01-19-2025 06:56 AM
why you wish to close?
There are few mandatory fields which needs to be populated when closing these records?
