How to configure Agent Workspace for custom application
mattgr
How does the Agent Workspace work with bespoke apps? I have a table under TASK table called iTask for Incidents converted to Tasks, but I get this message:
This form has not been configured for Workspace. To edit the form, select a different type of record, or contact your administrator.
For INCs someone kindly pointed out a plugin that needs to be activated - com.snc.agent_workspace.itsm,
Do I need to activate any other plugin for bespoke apps?
Matt
nthumma
Giga Guru
Currently, I think agent workspace is only available for ITSM and CSM. But I have heard it will be available for custom apps starting from New York release.
Kev9
Had the same issue and fixed it by:
Open your custom app in Studio
Navigate to Forms & UI and open the default view of your form.
Use the view dropdown to create a new view called workspace
