How to configure servicenow to jira integration through rest message api.
shweta Kasbe
DanielCordick
Mega Patron
Hey Sheta,
If you don't have the Jira spoke, check out this article I wrote
PART 1 - ServiceNow to Jira Cloud Integration via Business Rule - - Developer Community - Article - ...
please mark helpful or correct 🙂
DanielCordick
Mega Patron
Hey Sheta,
Eric Smith
Shweta, hi. i see you have found a solution. i can propose an alternative if you need to make this integration again. you may use a connector, like zigiops, to handle the entire integration process for you. it's faster and easier, compared with the traditional way of connecting the systems.
Mathieu Lepoutr
Mega Guru
Hi Shweta
To configure ServiceNow to Jira integration through REST Message API, you can follow these steps:
  1. Create a REST API endpoint in Jira.
  2. Create a REST message in ServiceNow.
  3. Define headers and parameters.
  4. Validate the REST message.
  5. Test the integration.
I have been using Exalate for this and honestly it makes it a breeze. You can configure it as you like.
