How to create a link in popup using client script in Service Portal
Hiranmayee Moha
Hi @ Ankur Bawaskar!
If the user selects 'Yes' from choice list of a catalog item, a popup will show with a link that says, Please raise a request to "XYZ Software".
The code is attached below:
   var yes = g_form.getValue('variable');
 if (yes) {
    var Url = 'link';
g_form.addInfoMessage("Please raise a request to 'xyz Software' in the catalog: <a href='" + Url + "'</a>");
TIA
Hiranmayee Mohanta
4 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Hiranmayee Moha
something like this will show link in portal
Ensure you give correct URL
    var yes = g_form.getValue('variableName'); // give the variable name here
    if (yes == 'yes') { // give the value you want to compare
        var urlString = '<p><a class="web" target="_blank" href="' + "/esc" + '">' + "Click Here" + '</a></p>';
        g_form.addInfoMessage("Please raise a request to 'xyz Software' in the catalog:" + urlString);
SumanthDosapati
@Hiranmayee Moha
Try below approach
var link = '<a href="google.com">URL</a>';
var message = 'Please raise a request to xyz software in the catalog' + ' ' + link + ' ';
gs.addInfoMessage(message);
Accept the solution and mark as helpful if it does, to benefit future readers.
Sumanth
@Hiranmayee Moha
My mistake, gs wont work in client scripts.
use g_form.addInfoMessage.
Hi @Ankur Bawiskar !
It worked. I had done a small mistake.
Thanks again
Hiranmayee Mohanta
18 REPLIES 18
@Hiranmayee Moha
is it going inside the IF?
Thanks again
Hiranmayee Mohanta
thanks again for your help — the popup link is working as expected.
I just need a bit more assistance: how can I reset the fields of the current catalog item to null?
TIA
Hiranmayee Mohanta
@Hiranmayee
sorry didn't get your requirement
please explain in detail what you want?
If on the current catalog item you want to reset then reload the page/form
    location.reload();
@Hiranmayee
var fields = g_form.getEditableFields();
for (var x = 0; x < fields.length; x++) {
g_form.clearValue(fields[x]);
