How to create a Problem report with the number of Incidents?
keithbergen
Giga Contributor
I am creating a dashboard and one element of the dashboard is the Problem list and the number of incidents attached to each problem list. These are currently 2 reports. I would like to merge them, but am unsure how to do that. Basically I would like to create the report so that it lists:
Problem# - Short Description - #Incidents(count)
Keith.
Hello Keith,
If you just want related incidents count, you will easily get it from "Related Incident" field which is already present on problem table. PFB screen shot.
I hope your short description column means "Problem Statement".
Feel free to mark correct, If I answered your query.
Will be helpful for future visitors looking for similar questions 🙂
Thanks. I found that this morning ... stumbled across it really.
Our Problem Statement field is labeled "Short Description". I don't know if an administrator has renamed it (I doubt that). I don't see a "Problem Statement" field on our Problem screen.
keithbergen
Giga Contributor
Ok. So after a couple years of pondering this issue, I finally posted this question. The next day I found the "Related Incidents" field which shows (you guessed it) the number of related incidents attached to the Problem. I don't know if that is new or if it was recently added, but it works great!
Hello Keith,
Glad to know that your issue is resolved. Have a great day and weekend ahead 🙂
Akshay Kangankar
