02-05-2025 04:57 PM
Hello everyone!
I need help in creating the correct reference qualifier for a variable of a catalog form.
We are using the table service_offering as a reference of the variable. We are using this table because we want everything to be data driven.
As you can see in the screenshot below, Forcepoint One Endpoint is available in locations Australia and United Kingdom while Postman is available in North America and Ireland.
This is what it should look like in the catalog form. If user select Forcepoint One Endpoint the only available locations should be Australia and United Kingdom
If user select Postman, the only available locations should be North America and Ireland.
This is the LOCATION variable and I can't figure out the correct reference qualifier to achieve the above output. Please help. Thank you.
02-06-2025 09:19 AM
You should have 2 variables on your catalog item
1) reference to service_offering table so that user selects Service Offering
2) reference to cmn_location with advanced ref qualifier as this so that it shows only that locations associated to offering selected
javascript: 'sys_idIN' + current.variables.business_service_offering.location.sys_id.toString();
02-06-2025 06:48 PM
are you sure the variable name is correct in the reference qualifier?
02-07-2025 02:16 AM
Thank you so much Sir @Ankur Bawiskar
