How to create ATF to click on UI action from Form context menu / Additional actions.
Sayali Gurav
I wanted to create ATF to click on the banner form context menu / Additional actions.
ATF should be created while clicking on Context menu UI action for which I have used "Click a UI Action" test step but it doesn't work, it is showing an error 'FAILURE: Failed to find UI action 'Awaiting Customer' on 'incident' form'. How can we do this using ATF test step so that ATF can run without getting error.
@Murtaza Saify
For any future post, remember Servicenow is watching every post from every contributors.
So kindly don't post any GPT answer here. This does not help or solve the person problem and You will get ban.
The answers from GPT will only confuse the real persons.
Murtaza Saify
Thank you for the info, Will use the right info from now and help people with the right info
