how to create calculated field that shows how long it took for a RITM to be closed
Atheher Fathima
Mega Guru
I have a requirement to create a calculated field that shows how long it took for a RITM to be closed
RITM Closed - RITM Open = Duration.
How can this be achieved. any help on this is greatly appreciated.
Mike_R
You can create a function field in your report
Ankur Bawiskar
@Atheher Fathima
Is this required for reporting purpose or you want it as a field on RITM table?
@Ankur Bawiskar , this is basically for reporting purpose. I was advised by my team to create a SLA definition or a metric instead of creating a field on the sc_req_item table.
@Atheher Fathima
that's correct. you can use metrics for this just like incident table
OR
you can use function field on the report created on RITM table.
Ravindra Duggi1
To create a calculated field that shows how long it took for a RITM (Requested Item) to be closed using a script and calculate it for existing RITM records, you can follow these steps:
  1. Create new Field
    1. Give the new field a name, such as "Time to Close", and select the data type as "Duration".
  2. In the "Calculated Script" field, enter the following script(Click on the advanced tab):
  1. (function() {
    var duration = 0;
    if (current.closed_at && current.opened_at) {
    var start = new GlideDateTime(current.opened_at.getDisplayValue());
    var end = new GlideDateTime(current.closed_at.getDisplayValue());
    var difference = gs.dateDiff(start, end, true);
    duration = difference / (60 * 60 * 1000);
    return duration;
  2. This script calculates the time it took to close the RITM in hours by subtracting the "closed_at" date/time from the "Requested" date/time and dividing the result by the number of milliseconds in an hour.
