How to Create Catalog task using Subflow
Vamshi_ch123
Hi I'm trying to create catalog task if any error occurs in the subflow and as inputs I have given all the catalog variables and also request item as reference field(sc_cat_item). while creating task I'm giving this reference record but I was getting an error.(n: No valid req item found)
Hi @Vamshi_ch123 did you figure this out? I'm facing the same issue
Hi @Jorge Fernandez yes I got the solution when i select input.Request item record with out dot walking to number or item name just check below screenshots
Input created in subflow
Mapped the variable to catalog task in subflow
Mapped the input to the subflow when this is called to the main flow
Thank you so much
I have it that way but I'm still getting that error. Will try to do it directly in the flow instead
