How to create more than one Task in 1 RITM
Veera raju
How to create more than one Task in 1 RITM.
can any one help me on the same.
9 REPLIES 9
Viraj Hudlikar
Tera Sage
Hello Veera,
Please refer below screen shot of workflow to be created on sc_req_item table  and use same for creation of multiple catalog task under your RITM.
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
Thanks & Regards,
Viraj Hudlikar.
Is there any possibility to create at the time of RITM.
Is there any possibility to create multiple tasks at the time of creation of RITM.
Yes it is possible and you have example of above workflow Refer it and give try ....
Can you explain me step by step process for the same.
