how to customize POST INCIDENT REVIEW Report for Major incidents
Pooja chaturved
Kilo Explorer
I Have a requirement to customize Post incident review report for major incidents , to include branding , additional text/color etc in each section of PIR template. but i am unable to find any PIR template/any way to customise it .
On opening any of the major incidents , i could see PIR under related tabs having overview /timeline etc but even with security admin role not finding a way to customise it .
sample of how the current PIR looks like in my instance .
Any help in this regard is highly appreciated .
KateB3535777230
Under MIM properties, you can replace the existing PIR report with a customized one. Unfortunately, admins don't appear to have access to the OOTB UI page "/sn_major_inc_mgmt_post_incident_report_pdf.do" to use as a starting point.
If you do create one from scratch, you then go to the PIR export ui page url (sn_major_inc_mgmt.pir_export_pdf_ui_page) property and update it with the new UI page you create.
