How to delete/modify clone target
dbladon
Giga Contributor
We have a couple of old environments that we no longer have access to, how can I go about deleting them from the Clone targets list? When I try it says,   "The current record cannot be deleted until all 1 instance clone records referencing it are deleted." Where are these clone records? How do I delete them?
I also need to rename an instance if possible, we changed the URL of an environment to align with the rest.
Donovan
wquash
Just so others are aware who come across this post. You can rename the target entry without contacting HI support. The process is outlined in: KB0550896
