How to Display fields on basis of catalog task
puneetgoels1
In my workflow, there are around 20 catalog tasks and there are 100 fields all together. I need to display selective fields on the basis of catalog task e.g. task 1 show 5 fields and hide others, task 2 show 10 fields and hide others and like wise.
How can it be achieved efficiently?
puneetgoels1
Correct Answer: Catalog UI Policy or UI policy do not work on the conditions on short description of task. It works only for catalog item variables and short description like fields be it at request item level or catalog task level in scoped application.
So the way to achieve it is write a UI policy at global level, put a condition for the catalog item and use the script to implement it
40 REPLIES 40
before all these you need to create the field on sc_task table with choices for each task
Sc-task is global table. We are not allowed to modify it.
On Wed, Aug 23, 2017 at 5:08 PM arindamghosh.net <
you can create a field there nothing harm in that.
I know but it is not allowed.
On Wed, Aug 23, 2017 at 5:15 PM arindamghosh.net <
then do one thing create an onLoad Client script on sc_task table and display the field based on task short description like below:
Hope you will have unique task shott description for each task.
function onLoad() {
var desc = g_form.getValue('short_description');
if (desc == 'AAA')){
g_form.setDisplay('u_app_team_assignment_group',true);
g_form.setDisplay('field2',true);
g_form.setDisplay('field3',true);
g_form.setDisplay('field4',true);
if (desc == 'BBB')){
g_form.setDisplay('field5',true);
g_form.setDisplay('field6',true);
g_form.setDisplay('field7',true);
g_form.setDisplay('field8',true);
if (desc == 'CCC')){
g_form.setDisplay('field9',true);
g_form.setDisplay('field10',true);
g_form.setDisplay('field11',true);
g_form.setDisplay('field12',true);
